So I went to install the Rough Country 4" lift in my TJ this weekend. Of course I hit a bump in the road. When I tried to remove the front lower control arm bolt, the bolt had rusted into the bushing sleeve. In speaking with a few buddies and my friend whose a mechanic he mentioned there are adjustments in the control arm that keep it aligned? Some sort of essentrics? So two things, A) Where can I get replacement bolts, and B) What the hell do I google search to find them?
TJ 4" Lift
eccentric cam(short for camber) bolt... fuck those things. they are gay
as far as getting the bolt out, have you tried heating it up with a hand held torch and pounding it out with a mini-sledge and a punch?Last edited by grundlepunch; 04-01-2010, 09:49 AM."when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Yup, melted the stupid bushing around the sleeve.Originally posted by grundlepunch View Posteccentric cam(short for camber) bolt... fuck those things. they are gay
as far as getting the bolt out, have you tried heating it up with a hand held torch and pounding it out with a mini-sledge and a punch?06 Wrangler TJ 6 Speed 4" Rough Country Lift on BF Goodrich 33's.
just sawzall thru the stock bolt and replace with some grade 8 9/16" bolts
you doing the 2.2 shocks ?
just a tip, your shocks and steering stabilzer, coat them with a good quality clear coat or paint. The paint RC use's holds up like 3 months and then starts rustingup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
I think I bought the X series 4" kit? I got it from JCwhitney and found a 20% off coupon code. Ended up shipped to my door for like $400, so I don't believe I had the option to upgrade to the 2.2 shocks.
So do I necessarily need this essentric cam? Or can I get off with just using some grade 8 9/16" bolts? If I can get away with just buying the grade 8 bolts where the hell can I even get them?06 Wrangler TJ 6 Speed 4" Rough Country Lift on BF Goodrich 33's.
fastenall has grade 8 bolts and you try soaking the bolt in kroil for a day that ussally works for me2000 xj 4.5 clayton longarms with wontons with a touch of
97' zj
2012 surbra imperza DD
