Building a HD crossmember.
  • Building a HD crossmember.
    I want to build a HD crossmember for my xj. Anyone have pics or tips on how to do this?
    www.pirate4x4.com
      Originally posted by XJtheXtremeJeep View Post
      x2
      you are dead to me
        take a look at csaddicts build thread, he build a crossmember thats pretty stout yet simple
          http://sisoffroad.com/forums/showthread.php?t=75
          Now that I did it, I would do it different next time.
            Yeah I looked at yours dave. I kinda wanna do like Sam did on his last build so i can get more clearence.
              that is one beefy crossmember.
                mine was super easy to make, had no bolts hanging below the framerails and was nice and flat.
                the downside is you need to clock your t-case. with an aw4 it's simple because its almost like the output housing was made to be clocked leaving more than enough meat to simply redrill the t-case mounting holes. not so sure with an ax15, but you may need a clocking ring (about 70 bucks) I made a little tool to do this effectively.
                this also raised my drivetrain about an inch.
                the only reason the clocking was 100% needed was front driveshaft clearance with how my t-case "set in" to the crossmember a lil bitty. without it my shaft would hit my crossmember at rest nevermind droop.
                i also had to cut a little "wing" off the 231 and pound my floor up a couple inches.
                but i liked it.
                oh yea it was basically a big hunk of 2x6x1/4" box steel
                    Hey sam do you have a pic of the holes you drilled to clock the t-case? Did you just drill it like a 1/4'' to the right of each hole.
                      just drill a little clockwise to each hole
                      i reccomend making a jig for it
                        Sounds easy enough, guess I should also ask if this was done when you had made your own linkage or does the factory linkage adjust enough to still work fine?
                          im not sure
                          i did the tummy tuck at the same time so i needed new linkage anyway.
                          it cost me like 15 bucks in heims and bolts. much smoother/firmer shirt operation than stock
                            And far less complicated..last question i swear..where did you get the ity bity heims and whatnot.
                              the internet
                              i think it was some race shop
                              i used all 7/16" stuff
