Anti-wrap bar
  • Anti-wrap bar
    new welder
    i have the bar all made up, and the mount to the skid welded in, and i just have to finish welding the brackets to the axle
    that looks good.
    #becauseJoeNitro
      finished melting in the brackets put everything together popped it in 1st gear on the street and no axle wrap at all. this means no more broken driveshafts.
        nice work, in case you have problems with that here is my solution to axle wrap
        1950 Willys Trail Rig
          I bet you are stoked to have a welder, welcome to fellow HOG (Hobart Owners Group)
            i've been welding non-stop since christmas morning, more stoked i can put all the plans i've had into product
              just wait till this summer when i have a lot of time, i have been thinking my front suspension hasn't been flexing enough
                p.s. i'm going to an engineering school that has every cutting machine, cnc, bender, welder known to man.
                  They let you use the equipment for personal projects??? What school is this?
                  You're a ___________
                    You might want to use a Johny Joint or rod end instead of a poly bushing. The poly bushing might hinder ariticulation.
                      have you come to this conclusion after wheeling it or just flexing it out? i would keep the front springs and the read linked if you want to link an end
                        if the rubber bushings do limit articulation i will add a jonny joint at the end of the bar
