Sway Bar Disconnects?
  • Sway Bar Disconnects?
    I have the need for some sway bar disconnects. I was wondering if any of you have fabricated any and was willing to explain how.
    Lift: 4.5" RC
    Tires: 33" BFG A/T's
    Misc: Hamerred Tan Paint, Homemade Roof Rack, Bumpers and Half Doors.
    http://www.4x4xplor.com/homediscos.html
    i had this same setup b4 i had my anti-rock
      Dont run Swaybars?
        I run JKS discos in front then made a cable disconnect to hold them up and out of the way while I wheel.
        The cable set-up
        http://www.jeepin.com/features/dpg_d...bles/index.asp
        A pic of them holding up the discos on my Jeep:
        Hope this helps
          i used to have quick disconnects... i might have used them once before they ended up in my fire pit...
            I don't run any, they are a pain in the ass. You can make some for cheap using cotter and clevis pins that you can get from your local hardware store. Just drill a hole through the top of the threaded end of your end link and push a cotter pin through. or don't run any.whatever your junk will be fine
              Isn't the roll around corners bad though? or at least thats what i've heard.
              Lift: 4.5" RC
                unless your name is Mario Andriette you'll be fine.
                learn to drive without it and you will never regret it...
                  you will roll into an oncoming buss filled with pre-schoolers on their way to an orphanage, the buss will then collide with a school for bunnies
                  j/k you will be alright
                    i have the jks's on mine and they're adjustable so you can adjust them if you decide to do bigger down the road...
                    also mine is a daily driver....
                      who uses sway bars anymore
                      I once had a 93 XJ, 4.5" o' lift, 33" TSL Super Swampers, 8.25 rear Detroit locked. 2,000 Lb Steering. Custom rockers, Sam's old Bumpah. Cherry Bomb BITCH. SOLD
                      Fight Team
                      Official HMC Girlie
                        i dont run any GO LEAFS!!!!!
                          An easy way would be to replace the uppe nut on the link with a wing nut... super easy and pretty effective.
                          2013 F150 fx4 (Tow Pig/DD)
                          • 5.0 with the 3.73 option
                          2003 TJ Rubicon
                          • 4.0/42rle/np241or
                          • 5.13's
                          • 33” BFG KO2s
                            depends.
                            back when i was on 31s with the front sway on, the jeep handled extremely well. when i went to 33s, i still ran it for a short while, then my quick disco holders broke in the middle of RC, so i unbolted the sway bar and threw it in the back on the jeep and never put it back on. with the soft rusty's shocks and springs, the roll was pretty bad, but not uncontrollable. now with the stiffer RE coils i'm running and the 5150s at each corner, its definitely much more controlled.
                              X2
                              1998 XJ.....Finally.
                              1997 ZJ 4.0L....The wife's ride.
                              ...And I'm a Mac
