Bumper build- JCR style
  • Bumper build- JCR style
    I'm building this bumper for pedro and will essentially be a JCR stage 1 without a hoop. unless he can get me some roundbar within the next week i dont think that is happening. It will be a replica of mine but with side protection. The metal is .125 wall 5x2. and the side protection is 2" box tubing with a .125 wall. Everything was goin smooth until I realized the main center beam was cut 4 inches too short. no it wasnt me who did that. so I had to cut the bumper in half and put a 4 inch spacer in. It actually turned out pretty well with the spacer. This is the first bumper I have built and my welds arent perfect but not bad. but I'm just learning, so fuck you bigbadxj. I have most of it done already. I just need to weld up the bottom plate on the end pieces and grind down the welds, and get it fitted properly. Im using 3/16 plate for the mounting brackets and they will be trussed for extra strength. and pete is gonna buy some D ring tabs to weld onto the front from AtoZ fab or BTF or something. not bad for a $50 bucks worth of metal. yay surplus city.
    Pics:
    Essentially it is going to look like this.
    side protection metal:
    build pics:
    I cut out the end caps by hand out of the 5x2
    welded up the main part. with an angle on the end pieces
    my welds. go easy on me and the pics are upside down
    side protection added. the corner and underside of the end caps will be plated. also the ground down spots in the middle is where i made the spacer. I just need to do a little more grinding to get the high and low spots out but you can barely tell unless you look at it anyway
    thats all I have for pics now. and Im out of grinding wheels
    Looking good dude. I need to build a front bumper.
      HOONIGAN FOR LIFE
      OLD 4X4'S NEVER DIE!!!!!
        badass sir. I don't care about pretty welds.
          ahem peter, buy these
          http://atozfabrication.com/store/pro...cat=275&page=1
            JCR has them for 13, but a different style. I think i like the A to Z ones better
              so order. d rings you can get at tractor supply for cheaper
                I just ordered the JCR ones. They were 18 shipped whereas A to Z wanted another 12 bucks for shipping
                  what kind of welder are you using?
                    Nice work. I'm planning the same design for my first welding project in the next few weeks....except using 2"x5" tubing with 3/16" wall.
                    I'm going with a front hoop that comes up a little higher....up to the top height of the header panel.
                    Gotta love DIY and the $$ savings
                      eff those, get one that goes THROUGH the bumper onto the mounting plates.
                        lincoln 175 mig
