1999 Cherokee SE
4.0
AW4/231
d30/8.25
123k
Bought for 600 bucks in September of 2008
Put foglights on it, October 08
Got it bogged and pulled out by the axle because i was a dumbass and went mudding with no tow points, Oct 08
Extinguisher #1
January 09- Put in a K&N CAI
1st iteration of the lightbar... they never got wired up. Feb 09
LIFT! April 09, 3" Skyjacker AAL (
i didn't know any better) with quick discos. took the time to wire up Hellas on the roof. Changed front left bearing assembly and rear diff fluid at the same time. no pics of the rear install, but all four frameside shock bolts snapped as is usual
. I impact hammered the broken bolts out and fishwired new ones in.
First time taking it out after the lift. Gawd i needed to cut my hair. April 09
Late June 09- mah 231 goes boom on 84, all the fluid spills out and gets all over my rear tires, which start fishtailing. I shit a sideways brick, but get it under control and off to the side.
Looking at the carnage after I got it towed home, I found out why it grenaded, and what the squeaking noise i occasionally heard had been... the CV joint on the T-case side of the front driveshaft was dying, and had finally siezed and torn the T-case apart. Bought a new T-case for 200 bucks, came with a ZJ front DS and d-30 shafts. Keeping the shafts for spares.
Tow hooks, July 09
31's, November 09
Bedlined rockers/fenders, November 09
33's, Jan 10
Fender trims, Jan 10
Non-idiot-light cluster, Feb 10
Bumpa (ty Caleb), March 10
Doorless in front (also ty Caleb), March 10. Killed a Dremel in the process.
Dat's it so far. theres stereo shit and minor rewiring in there too, but no pics of install.
4.0
AW4/231
d30/8.25
123k
Extinguisher #1
Tow hooks, July 09
31's, November 09
33's, Jan 10
