Firearm Build Thread
  • #76
    Carbine:
    CMMG MOD4SA Lower
    Rock River Arms Parts Kit
    Bushmaster Flattop Upper w/ Rock River Arms Bolt Group
    Yankee Hill 16.5” 1-7” CL Barrel
    Cavalry Arms Muzzle Brake (pinned and welded)
    Magpul MIAD Grip
    Yankee Hill Flip-Up Front Sight
    A.R.M.S Flip-Up Rear Sight
    Rock River Arms Charging Handle
    ACE LTD SOCOM Stock (pinned)
    MidLength:
    Rock River Arms LAR15 Lower and Parts Kit
    EoTech Holosight
    Troy Medieval Muzzle Brake (pinned and welded)
    Rock River Arms Bolt Carrier Group
    ACE LTD Skeleton Stock
    Magpul MIAD Grip
    Troy Gas Block
    Troy 10" Modular Rail Forend
    Magpul MBUS Front and Rear
    Rifle:
    Colt Match Target Sporter Lightweight and Colt Parts
    Yankee Hill Flattop Upper
    Colt Bolt Carrier Group
    Colt Charging Handle
    Jard Match Trigger
    Colt 20” HBAR Barrel
    Yankee Hill Lightweight Forend
    Magpul MIAD Grip
    Yankee Hill A2 Rear Sight
    I'm working on my fourth one now.. < Dead Serious Face. I've got all the parts to build a fourth one, just need a lower and parts kit. It won't ever end.
    • #77
      Phil, I truely am jealous. If I ever saved up enough money, would you part with one of these bad boys? I'm not sure about which type I'm into yet because they all look so sick
      -Matt
      Facebook
      • #78
        hahaha, probably not, but I can always lend a hand when you want to build one. Plenty of parts are available, you just need to know what you need and where to get it.
        • #79
          pics of that marpat 10-22
          • #80
            Made this for Desert Metal.
            Took a small piece of Sched-40 and made a threaded insert for it and a parent piece that will hold the mount.
            The Sched-40 piece would be eventually welded to the Cage on DM.
            KNS Precision Spade Grip kit. Turned my AR Rifle into what you see here: A fully functional spade grip AR15 for mounting on vehicles.
            • #81
              tis too bad it was only mounted there for 20 minutes and never again
              • #82
                It will relive on the next DM.
                • #83
                  guess you arent familiar with prototypes!
                  • #84
                    Sort of Want.....................
                    • #85
                      Hurm. AR has been done for a while now.
                      Here she is. The Dissapator Carbine next to the M4gery
                      [/quote]
                      shit is ill !!!
                      pros / cons of doing a "carbine" or a "midlength" or is it preference of looks and barrel length?
                      i dig the smaller carbine, and i dont like the full rail system (i like the magpul MOE hand guard). can that be installed on any barrel or do i need specific equipment to run the "carbine" look
                      • #86
                        Originally posted by grundlepunch View Post
                        shit is ill !!!
                        A Carbine, Midlength and Rifle are all based on the placement of the Gas Block on the barrel. A Carbine with a 16" barrel is the norm. The Magpul MOE handguard is good shit, I plan on getting one for a later build myself - I find myself partial to Magpul furniture because it kicks ass.
                        For a Carbine Specific build, all you need is a Carbine Barrel and a Carbine Gas tube. The MOE hand guard is designed for a Carbine so it will bolt right on. The front sight you choose doesn't matter, but you will need the forend retainer for it, it is a stamped piece of sheet metal that goes behind the front sight that holds the front of the hand guard.
                        What really makes a carbine a Carbine in the AR world is lightweight and barrel length. either a 14.5" barrel with a soldered / pinned compensator or a 16" barrel like what I have and a pinned compensator.
                        YHM (Yankee Hill MFG) Makes a good Carbine barrel that is reasonably priced and good quality.
                        Also, do you want a folding sight like the one I have on my carbine?
                        • #87
                          i like the flip up brass sights and would also like to have an eo-tech (like the one you have?). I think that was the brand i used once and it kicked ass
                          • #88
                            Yeah, EOTech. Good shit.
                            • #89
                              Added some new stuff.
                              Troy 13" rail and Magpul Angled Grip.
                              Finally ended up with a Dissipater Carbine I'm happy with.
                              • #90
                                Swiss Zombie
