Operation: BACK IN BLACK! 97 xj build
yea the allieds call for the final torque between 12 and 15.Originally posted by Jeepbonehead View PostI was thinking 10-15ft/lbs but I hadn't see anyone post how tight they made theirs. Thanks
there are 32 per wheel and they are 5/16 in diameter
sam did you use your hobart 140 to build everything on your jeep or use someones 220?89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
just about everything was done using my 140. and everything that wasnt could have been.Originally posted by WAD357 View Postsam did you use your hobart 140 to build everything on your jeep or use someones 220?
i only used my buddies 110 for a few things and the cheap pile of crap 220 at work for a few things. i just used whatever welder that was around at the time i wanted to weld lol.
alright man im just thinking as far as my next build will go what i can do with the 140. As far as axle brackets I'll probably tac them and then hit them with a 220 thanks dudeOriginally posted by Ktmracer419 View Postjust about everything was done using my 140. and everything that wasnt could have been.
i only used my buddies 110 for a few things and the cheap pile of crap 220 at work for a few things. i just used whatever welder that was around at the time i wanted to weld lol.89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
axle bracketry and link mounts, leaf perches and whatnot were welded with my 140 4 years ago.Originally posted by WAD357 View Postalright man im just thinking as far as my next build will go what i can do with the 140. As far as axle brackets I'll probably tac them and then hit them with a 220 thanks dude
use as lil extension cord as possible and keep the heat up. never had a problem
good to know maybe Ill just go for it then thanks again for the insight dudeOriginally posted by Ktmracer419 View Postaxle bracketry and link mounts, leaf perches and whatnot were welded with my 140 4 years ago.
use as lil extension cord as possible and keep the heat up. never had a problem89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
im curious to know if you still have 3" in the front and around 5" in the rear.. and if so, why? is it like a leveling type thing? you know, full tank, tools, recovery gear, tire carrier etc.? ive been thinking about going an inch higher in the rear for similar reasons, if thats even remotely the reason you did it...Watch your backhoe, I'm the John Deere man.
nooooOriginally posted by 93XJRay View Postim curious to know if you still have 3" in the front and around 5" in the rear.. and if so, why? is it like a leveling type thing? you know, full tank, tools, recovery gear, tire carrier etc.? ive been thinking about going an inch higher in the rear for similar reasons, if thats even remotely the reason you did it...
its more like 4.5" front, 3.5" rear now
when i swapped in the 44 my perches gave me some lift. and after the cross country trip with 3 people and thier gear for a month including tools and spare parts it killed my leafs pretty good.
i want to bring the front down a touch and the rear back up to maybe .5-1" higher than the front.
seriously debating ditching the coils and going to coilovers in front when i cage it. get some deavers in back with halfway decent shocks and call it set.
but thats still kinda in the dreaming stage right now.
Originally posted by Ktmracer419 View Postseriously debating ditching the coils and going to coilovers in front when i cage it. get some deavers in back with halfway decent shocks and call it set.
Based on your track record of putting cages in jeeps before you destroy the unibody, I lol. But if you prove me wrong and include the coil overs, I will give you a cookie. sound like a deal??
2013 F150 fx4 (Tow Pig/DD)- 5.0 with the 3.73 option
- 5.13's
- 33” BFG KO2s
hence the
Ok, I was just curious. I'm going to throw some shackles in the rear to bring it up a bit over the front. I was happy with the setup I had in my 93, the shackles flexed fairly well and believe it or not my ride quality in the rear was increased. Also I'd like it to be fairly level with a full tank and gear and whatnot. Thanks.Watch your backhoe, I'm the John Deere man.
