The HeavyMetal Project
toyo / irok ?
Just don't use those retarded carriage bolts.Originally posted by HeavyMetal View Posti have aftermarket plate LCA brackets, otherwise yeah i suppose...
i need airbumps and leafs before a truss...oh and a straighter unibody.
the stock mounting method is gay as hell and im tired of bar pins, so I wanna do this for the shocks before i put em in:
You're a ___________
thanks for the link mike, but they got too much stroke to em...plus im gettin a little bit better of a price...I may be going radflo instead of SAW now at the suggestion of a friend...lots of options it seems...- Will
http://pirate4x4.com/forum/showpost....3&postcount=27
Originally posted by downtowncbFinished finals, now I get to work on the Jeep once again. Got the air bump brackets welded to the frame this evening.
Here is full droop, right now they're setup for 4" of travel but thats way to much for my needs so in the future I'm going to limit them to somewhere near 2".
Here is full bump, they contact a UHMW disc on the LCA bracket.
2013 F150 fx4 (Tow Pig/DD)- 5.0 with the 3.73 option
- 5.13's
- 33” BFG KO2s
man that looks sweet as hell
but
my TNT arms are way inboard with the bend in them and all, theyre on the inside of the unibody rail...not sure if i wanna deal with the hassle of gettin in there on the inside to do it..
either way thats something i still need to think about, mounting methods...
these came in the meantime:
pulled the 5150s out to find a toasted bushing and 2 less than ideal bar pins...so time for BPEs, i think.- Will
i have these welded in the back and they have been great for years
http://www.rocky-road.com/xjbarpin.html
or for the front
http://www.rocky-road.com/pinadapt.htmlI drive a Datsun
was originally buying a set with heims, then got this set instead...one less set of heims for me to wear out...i dont think ill see too much of a loss with the rubbery goodness anyway for my applicationOriginally posted by XJLI View Postyou should really swap out the rubber ends for the fox heims- Will
