what kind of shocks are those? ive never seen anything that fancy come from rough country
Project "RCKRDY-TJ"
Looks good
Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
i knew someone was gonna say it...... but the general consensous so far is that its fine how it is "note" how nicely it tucks on the tire stack bigger tires and your loosin flex and we arnt going crazy with this jeep like cutting fenders and what not.Originally posted by Pedro View Postlooks good!!, needs some bigger tarz tho#becauseJoeNitro
Did you disconnect the swaybars? It doesn't look like it in the pics. I'm running about 3" over-all lift in the front, and just 2" spacers in the rear, I'm not having any issues with stuffing 32"s. Just my $.02Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
Get some Quick disconnects, put the rear swaybar back. That way you keep all your onroad handling, and you can disco your front for max articulation, then reconnect once your off the trail. You can also leave the rear swaybar off, and get discos up front as well. Most people leave the rear on because it flexes anyhow, but helps reduce body roll on the road, so it doesn't greatly improve offroad performance to disco it. The front swaybar is much thicker and stiffer so any obsticle you go over, your whole jeep is going roll hard tward the lowside anytime your front axle goes off-camber, and without the tension in the rear, there is no resistance. Anyhow, JKS makes great front discos for the TJ, you can also do the budget ones I had for a while.
They were pretty much this set up.
http://www.rockcrawler.com/techrepor...ects/index.htmLast edited by bucketokarma; 02-09-2009, 09:25 AM.Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
glad i have you around to school me on how swaybars work. i dident know anything about them....
caleb we will prolly be gettin them discos i gotta get some money 1st. lol if i knew i was doing this i wouldent have sold mine
#becauseJoeNitro
You planning on putting the rear swaybar back in?Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
