98 DD/Weekend Bruiser
    So i got a couple things to up date on.. Got myself a set of used rcvs, new synergy ball joints, timken hubs and finally burned in the C gussets ive had sense i ordered the truss kit. And finally got some 35s, i really wanted the trail grapplers but it seems they arent available in the size i wanted so i just got another set of the dura tracs insted. They seem to do well off road and they are smooth riding tire for pavement applications...
    Just a little test with the new tires, i have sense trimmed the front flares out more but i dont have any pics currently with the flares trimmed.
    00 xj hp44 aussie lsd 5.38s, d60 welded 5.38s, 37" MTR Kevlars on 17" H2 wheels, chevy one ton steering, comanche rear leafs, 11" inch travel bilsteins in the front 14" in the rear
    98 xj hp30 open 4.10s, 8.8 lsd 4.10s, 33" duratracs on 16" moabs, ruffstuff frame stiffeners, custom 3 link 3/4 heims for the upper and 1.25 for the lowers, f150 10" travel shocks in the front with 3" coils and yj brake hoses, an extra main leaf in the rear and 1.5" lift shackles in the rear
      Boss at work helped me with making a tank and tcase skid, also finally got the rear wheel wells trimmed out finally. guess i forgot to upload pics of the tank skid.
      playing around with the camera on my phone..
        Nice!
        Sent from my pay phone in Chechnya
          Thanks man! Some battle scars from this weekend, guess ill be doing rockers at some point soon lol
            Did you make shoot the moon?
            General Tires are
              No, I was close till I started leaking oil from either the pan gasket or the rear main and that's when I stopped
                That blows dude!
                General Tires are
                  Anyone here delete the clutch fan and run double or triple electric fans? Good bad?
                    Yep.
                    I went back to the clutch after a day.
                    General Tires are
                      keep the fan clutch
                        Whats the bad?
                          Originally posted by Dozor View Post
                          Whats the bad?
                          No difference in power, higher temps, and a lot less to go wrong.
                          Hell for the summer extreme heat I even have a non clutched fan. It sounds like a jet but never gets close to 200 degrees wheeling.
                          General Tires are
                            Put these in cause the stock ones were no bueno....
                            Went with the ultra flex rubber, still definitely a lot stiffer then the stock mounts. Can't imagine what the polys would have been like..
                              Bought a new fan and made a shroud to replace the broken bulky plastic fan, seems to work just as good as the stock step up with room to spare.
                                Got one of the mini boat sides done this weekend, couldn't get the doors off and didn't really have time to mess with them So I just worked around them. Will be making them all removable in the future anyway.
