box with big wheels thing i'm making
  • Originally posted by Luke95 View Post
    Temper temper..... And I will have to modify my floor when I go flatbelly with a 231.....
    Hahah wtf what are you doing? None of my stock drive line hangs down below the unibody "frame" rail so to speak. No idea why you're doing all that with a 231, you probably have way more needed things to unfuck on your XJ.
    This a thread I started in pirate?
    I've seen pics of a doubler and flipped D300 under an XJ with no floor mods and the 205 is similar in size. Also this is going off of a 4.0/AW4 combo, I'm not sure where the 5.3/4L80e will end or how much I can tweak it. Hell then again I may have to cut half the trans tunnel out.
    • Originally posted by sardo_67 View Post
      I am clocking the t case and making a flat belly pan/skid and no not really other than a cage and replacing the cracked Trans from when I got hit it is done until I finish my tons.
      General Tires are
      • Post a side pic of your jeep to show how far down t-case hangs then. This seems pretty stupid given the extra what inch it will give you?
        • This is the thread with the pic I was talking about... I was assuming the person with the identical username as you was you
          http://www.pirate4x4.com/forum/jeep-...om-t-case.html
          97 XJ.
          • box with big wheels thing i'm making
            A flat belly, the ability to slide over a rock without getting hung up on it. And I will tonight when my Trans is back in.
            General Tires are
            • I know what a flat belly is, calm your tits.
              Mj question was what's the point for what 1 maybe 2 inches of clearance?
              • Low COG needs every bit of clearance you can squeeze...
                • Really? That's your response? Do you see your avatar pic Hux?
                  • And before you go ape shit I'm referring to your use of
                    • 1) that's full droop.
                      2) #suckit
                      3) at least it drives
                      • Low blow brah...
                        • Originally posted by Robin Fairchild View Post
                          And I'm fucking low. Like stupid low. Hux can verify this, I'm sitting at about 2.5 inches of lift with 3 inches of up travel 7 down.
                          I don't have a belly pan number, but it's low. My skid is dented to hell and back
                          General Tires are
                          • So raise up your rig then. Duh
                              And why do that? I love the stability.
                              General Tires are
                              • Did a lot of shit, didn't take pics, sold 37s like a dumb ass, bought 40" Kevlars.
                                Also put Asian eyes on my XJ, instead of those angry eyes everyone does.
