it's not a show car i wouldn't worry about perfection. shortening the frame?
HHHHWhite Powa Comanche
A pillar. This will tie into my unmade rocksliders.
B pillar tie ins. Also running a piece up and over the transmission hump and welded to the unibody there too.
Dark pic of the roof.
Pretty much got all the bending i need to get done finished. Now i need to waste another 50ft of DOM somewhere haha
Reinforcing the hell out of this rig. Been inspired by jeepspeed builds for reinforcement ideas.
Removing the stock suspension mounts and folded and welded the pinch seam and then welded a reinforcement plate over it.
Reinforcing the sides and underneath. Using LII 1/8 plates on the outside and plating the inside with 3/16 steel. Welded the seams on the unibody and welded the frame/engine plates to the body and reinforcing that.
Also plated over where the coil sits in up top...Maybe ill mount some air bumps to it someday.
[/IMG]
