The LiteMetal Project; "Theblackjeep"
  • Originally posted by Pedro View Post
    You need the overland seats now
    Been checking a couple times a week for a few months now...some idiot wants 800 for a set here
    the rest were gone before I could get em
    Soon.
    • Try jeepsunlimited in the wj for sale section. There used to be a guy always parting overlands out. Must have worked in a junkyard or something
      Here, found it and commented.
      http://www.jeepsunlimited.com/forums...nventory/page4
      Edit #2: now I know why i hadn't been on there in awhile. It's slow as fuck.
      • ZJ rear disc conversion done! Drums FTL.
        for the sake of tech:
        when converting to discs you need to have a spacer installed on the axle shaft in front of the seal...teraflex sells a part for this that is just a machined ring...a work around is all TJ Rubicons came with a retainer plate that had the spacer built in...the only catch is you need to redrill the rubicon 44 housing bolt pattern to the XJ one. a quick fix.
        You will also need to do the same redrilling to the disc bracket, as well as slightly open up the inside of the bracket center hole. Thank you to Phil for disc-smithing this one.
        thank you Kappy/phil for all the help installing, and dizzy for access to the shop. We went with XJ front hoses to run off the calipers for the sake of length for routing.
        • Hood release cable snapped, of course, because its an XJ. Loving these new hoodpins! AeroCatch
          • Those are sweet!
            • Those aerocatch pins are so nice
              • seen em for years and years, figured what the hell. never seen em on an XJ, haha
                • Such aero, so race car
                  • 2005 Jeep Wrangler Rubicon Unlimited
                    1945 Willys-Overland CJ2A
                    • Installed an ARB roof rack to accommodate the roof top tent when needed. This thing is burly.
                      • Is it running ok?
                          uhm yup
                          • Originally posted by Burton58 View Post
                            Is it running ok?
                            Smoothest running 4.0 in history at the moment..only because we seemingly replaced every single thing on it over the summer
                            • Will do you have a dana 44 in the rear or C8.25?
                              -54 Dodge Power wagon M-37
                              -57 GMC Pickup
                              -Tim (OIIIIIO)
                              • it has a D44
