My WJ Build
  • I like your dumpa, i mean bumpa
    • Picked up a set of JK Rubicon moabs for $150. Still need tires for them, but they will go on eventually.
      • totes adorbs
        • Were they plasti-dipped or something?
          • Originally posted by Robin Fairchild View Post
            • Andrew is actually getting the rims for the TJ, so I will not be using them. Jeep needs a few other things before a new set of tires/wheels.
              I did order a new IRO rear a arm, so that will go on eventually to help the rear pinion angle and take care of the vibes.
              When I can I want to take out the front axle and freshen it up with some new ball joints and upper control arm bushings.
              Winch after that.
              Almost wheeling season, need to make sure it's reliable.
              • Got the new a A-Arm in this weekend and corrected the pinion angle. Hopefully no more vibes. Also got my exhaust in finally. Magnaflow cat, Dynomax VT muff diver, IRO exit pipe. All 3". Much different sound...quieter....which is nice.
                • Dizz dizz go sleep sleep
                  • Finally got a new wench. Went with the Smittybilt X20 10k and a Warn Spydura 3/8"x100' rope. Just need a hook.
                    And a teaser for what's coming next weekend
                    • Things are coming together nicely.
                      • Pete got Nittos.
                        you spoil all of my posts
                        • Ugh its going to have 6x the traction than the last tires!
                          • oh and JK Moabs
                            • Bobby Darron, tomorrow.
                              • Bad things happened today.....295/70R17 Nitto Traill Grapplers on JK Moabs. 1.5" spacers.
