Project Mighty White
  • Project Mighty White
    I figured i should quit being lazy and continue my build thread on the new site. I haven't done much lately to the jeep but i have some big plans for it in the near future hopefully as long as money permits. First i need to fix up normal maintenance items though. Link from old forum build thread http://mrmontez2000.proboards70.com/...ay&thread=6197
    i will update the parts list with red text for completed items
    I will make list of plans and try to follow the list as i get my paychecks
    -replace P/S pump
    -buy/make a real 1 ton steering
    -get BPE's all around
    -replace t-stat/housing gasket
    -fix trans cooler line leak
    Larger plans for down the road
    -Find a deal on 33's/35's
    -Find 44's
    -lock and regear 44's
    -replace all 4 shocks
    -bumpstops
    -shave the head/port match head to manifolds on spare 4.0 and swap motors
    -tie in both bumpers
    new unit bearings yet?
      yes, i replaced both unit bearings with 1 year warranty ones from napa so if they dont die in 1 year i will return them a week before warranty.
        i will be picking up a pair of waggy 44's on sunday and then waiting for my money to come back for tax returns. plans for the axles include:
        -5.13 yukon gears
        -warn premium manual hubs
        -alloy shafts all around
        -lockers of some sort
        -1 ton steering
        I also pulled the valves from the head today so its all set to be sent out for some light machining.
          wooo
            sweeeet 5.13's and 31's
              5.13's and 31's>3.55's and 35's
                Sounds sweet. What size tires you plan on going to?
                  wat you trying to say here????
                    im looking around for a good deal on some 35's
                        damn right. i'm gonna swap out my 35's for a set of civic tires, much better gearing
                          picked up the axles today. seems like it would be a simple task but turned into a several hour job. Front wheels were basically fused together to the hubs/rotors. Ended up pulling the hubs apart and cutting the calipers off with a torch. Started stripping the axles down today and already broke a 19 mm on the shocks and a breaker bar and 3/8" ratchet trying to get the nut off the upper ball joint.
                            soak the livving hell outa that thing with pb for a week..... looks liek the good old northeast got to them
                              Those axles look like fucking hell. Fuck PB, get that goddamn wire wheel out.
