so im still having some bleeding problems with the new rear disk brake kit and zj valve, but if i pump them i can get them to act normal. so i decided to check how well they'd work in an emergency application and slammed on the brakes; without the tires screeching i went from 45 to 0 in about 2 jeep lengths on 35s. id say thats not bad, anyone have any comparable situations?
also anyone have any tricks to bleed all the air out? standard farthest to closest bleeding isnt really working for me, i had heard you can open all the valves and let the fluid run and keep filling the reservoir and eventually all the air will come out, i dont know how thatd work tho cause the air could just come back up into the caliper... any suggestions?
