There is a difference between being cheap and not just throwing away money unnecessarily.
A $10 part broke, and I purchased another $10 part. I don't get your comment about stock servos unless you think I broke my servo instead of my servo arm.
sigpic Official Space Shuttle Door Gunner of the Chechnyan Space Program
Its called a servo horn...
97' zj
2012 surbra imperza DD
Sorry I thought I did it was in draft from I was being a cookie so they turned my gas off so I had to turn it back on
97' zj
wasnt even from running it! Was driving to work with it sitting on the passenger seat and someone cut me off, sending my Wraith forward to fall off the seat front first.
If I recall, roughly the same thing happened to Dickerman, but Matt ghetto fixed it temporarily. Id love to know how
You just rotate the gear. The servo only uses about half of the teeth on that gear, so if you flip the gear so that the broken teeth are on the opposite side of where they were before, you should get one more use out of it.
#houseofhack
That... doesnt work for me. The gear has a little pin on the bottom side that hits a bump stop to prevent the gear from stressing. Turning the gear does nothing, since flipping it just makes the gear wanna turn past the stop.
