sye and new drive shafts?
  • sye and new drive shafts?
    will i need to get two sye's and two drive shafts when i put my 3.5 susp. lift on or will the sye by them selfs work?
    2000 xj 4.5 clayton longarms with wontons with a touch of
    97' zj
    2012 surbra imperza DD
    im a motivation machine like the hammer and sickle in communism
    first of all what vehicle is this for ?... if it's an XJ you wont need an SYE for that height, and to answer your question you will only need one SYE and one driveshaft
      its for a 97 tj, does the shaft flip work with the tj also?
      97' zj
        Unknown with the shaft flip. As to needing an SYE on 3.5", it varies from rig to rig. better safe than sorry and putting one on
          my jeep is like a black hole no matter how much money i put into it, itll never be filled
          97' zj
            Do the lift, then if you need the sye then get it. Every experienced mech. tells me, if it doesn't need it, then leave it the way it is.
              Especially with a wrangler, the shaft is so short that as soon as you start going up that driveline angle is immediately affected by it. I went through two or three shafts before i smartened up and got and sye and a tom woods.
              1981 CJ8 - old & dumb
              1988 Cherokee Limited - The Real Cherokee
              2001 TJ Sport - DD
                I have a TJ 4" kit and didn't have an sye for 2.5years. Never broke a shaft and DD it for 2 years. I just recently put in the sye and new shaft
                  I would do one to be safe and it is not that expensive at 175 bucks
                    i ran my TJ on 4" lift and would get some vibes at 70+mph from the rear driveshaft without SYE but did have a skid plate drop spacer on it but otherwise it was ok. ate a u-joint every so often although my driveshaft isnt exactly it the best shape ever since i grenaded my t-case output shaft + rear yoke
                      Do your kit and if you need to you can simply get a transfer case drop which can be only $20. This way you won't have to take time out to wait for an SYE. and if you want an SYE then you can simply take out the transfer case drop and put on the SYE. You can even make your own t-case drop with a pipe and 4 longer bolts.
                      Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
                      93 2DR XJ 8" lift D30/D44 4.56's 35" MTRs IRO Y-link Build:http://sisoffroad.com/forums/showthread.php?t=9658
                      Eric
                        I have tcase drop brackets, they even say SIS OFFROAD ON THEM. $500
                          ha for 500 ill just get an sye and a tom woods
                          97' zj
                            Yeah but heres the thing. None of that says SiS Offroad on it. These are precious. Anyway before you put your lift in, make sure to check these things before install:
                            Muffler Bearing
                            Halogen Light Fluid
                            Tire airators
                              what about topping my water level off in my diff's?
                              97' zj
