U-joints and rear driveshaft
  • U-joints and rear driveshaft
    Ive got a 95 xj and i need to do a driveshaft and ujoints. I heard you can use a front auto driveshaft for the rear.
    And also what type of ujoint do i use? 153x?
    you have to do a slip yoke eliminator in order to use a front shaft in the rear
      ok with that being said, how are the rugged ridge sye's?
        looks good to me, comes with everything you need. FYI it doesn't work for np242 transfer cases
          oh and the u-joints are spicer 1310
            well thats good because i have a np231
            now to the ujoints, what ones? are the tom woods superflex ujoints worth it? and what size?
              i have no experience with tom woods joints. i just run spicer 1310 joints from the auto parts store
                awesome thank you, my u-joints are clackity clack clack and I need to do them like yesterday. I figured since i was in there i would do the sye too.
                  If your going to do an sye then whybother redoing ujoints in your stock rear shaft, which post-sye will be useless? Better off putting money into buying new shaft vs. Old one
                    x2 i assumed you meant the front xj shafts for front and rear
                      yes hence why i wanted to know about using a front drive shaft in the rear.
                        http://www.performanceoffroadcenter....roducts_id=153
                        Here, it'll save ya a few bucks and is a great kit. It's what I ran and many others here do with no issues
                          the u joint is spicer part #5-153x
