Does anybody have or can take some photos of a Long Arm Xmember for a Cherokee? Gonna look into building one and i think im under thinking the design by alot. Ideas are greatly appreciated.
L.A Xmember
Thanks, i have steel from the front bumper build so it's 3x6x3/16. Just so happens i have enough to make that a xmember, use angle iron or something as the unibody mount, and use some of the 1/4 steel i have left over from tie ins as the arm bracket
Does this look good for strength wise? Also is there any places i can get just the lower arm? Making them would be just as much as getting the rustys lowersGod made the world in seven days, on the 7th day, he made the Le Car
I know i can fab them, but last time i priced it out, it was like $250 for all of it.
Where do you recommend getting the joints and the nut inserts? prefer to buy from one place if possibleGod made the world in seven days, on the 7th day, he made the Le Car
What size pitch and bore would anyone recomend? And if i buy these will i also have to get nut inserts?
http://www.ballisticfabrication.com/...ot_p_1646.htmlGod made the world in seven days, on the 7th day, he made the Le Car
If you get those, I would go with 1.25" 12tpi thread and 5/8 bolt hole.Originally posted by gobigorgohome View PostWhat size pitch and bore would anyone recomend? And if i buy these will i also have to get nut inserts?
1.25" 12tpi is a very common size and plenty strong. You could go with a 3/4" bolt hole if you really wanted, but that's a big ass bolt and kindof overkill for somebody like you and me. I'm going to be running 5/8" bolts on the track bar I'm building.
yep.Originally posted by Even View PostYours already giving you shit?
ive had to tighten em up 3 times
they will creak right after you tighten them for a week
then be nice and quiet for about a week, then begin knocking
then tighten again when you get sick of the knocking
Im thinking of just buying a kit, with my luck ill end up making a simple mistake and causing many headaches in the future. I would probably get tired of the project half way through and just wing the last half of itGod made the world in seven days, on the 7th day, he made the Le Car
