I have a question about welding.
  • I have a question about welding.
    Well my laundry list for things I have to weld is piling up. Firstly I want to get my old rocksliders welded in place to replace my rockers. Basically im just wondering if I can get a good enough weld to hold with my welder, im pretty much a beginner with welding besides screwing around a little bit here and there with some scrap metal.
    I only have access to a Harbor Freight 90 amp flux core, and a Miller 220 stick welder, the flux core doesn't seem like its gonna have enough balls to make a decent weld, I think the rockslider is 1/8th" thick, i'd try the Miller but stick welding on sheet metal scares me. I was thinking what I might be able to do is heat the rockslider with a Map torch and just work my way along in little sections with flux core, seems like it should make it penetrate ok, I can run up to 0.35 wire with it too.
    You guys think that will work ok for me, i'm not exactly a pro welder, i'm just getting to the point with the Mig where I can hold an ok bead and not have it come out all broken and clumpy looking. Looks aren't a super big deal though, as long as it looks decent from like 10 feet away, i'm bedlining over them any ways. Strength is what matters.
    id be able to make it work with flux, im not a pro welder by any means but i found a niche and have gotten flux core to work for me. practice more.
    1945 Willys-Overland CJ2A
      X2, I'm no expert but welding sheet to 1/8" the HF special will be great. Don't bother with the ARC, it'll just burn through if you aren't good at it
        x3 just get a good bead going and keep it goin
        Dizz dizz go sleep sleep
        Driver 4677 FSM vehicle
