I need some measurements
  • I need some measurements
    I would like some measurements of the following coils sitting at ride height
    stock xj coils height:
    1" lift coil height:
    2" lift coil height:
    3" lift coil height:
    Also what brand coil it is, and if you know the spring rate that would be stellar
    Thanks
    old man emu 930 coils 160 lb spring rate. I forgot what stock ride height is, but I know I netted exactly 2" from them when I measured
      can you get me a measurement from bottom of the coil to the top please?
        do you need compressed as in with the vehicle on it or out of the vehicle?
          with the weight of the vehicle on it
            ok gimme a sec i got 3 inch coils ill measure
              OP..... "I would like some measurements of the following coils sitting at ride height"
              ride height?
              just like lucas murphy in that lucas oil rig huh
                rough country 3 inch coils just put in today sit at 15 3/4 of an inch at 160 lbs/inch
                and zj coils that have been in for a while are 13 and 7/8ths dunno the spring rate on the zj coils
                  ride height?
                  he confused me when he said just from the top to the bottom of the coil in the other post... i read the original at a different time from that post lol
