leaf spring bolt issue
  • leaf spring bolt issue
    typical front leaf spring bolts are stuck in the bushings of my leafs. the bolt is maybe half way out but i think the bolt is turning the rubber bushing inside the spring...
    any tricks to getting the bolts out?
    Turn the bolt with a ratchet while someone applies pressure to the bolt via prybar or big scree driver. If all else fails cut it out.
      Is the bolt unthreaded all the way? or is it still in there?
        sawzall, angle grinder, and cursing usually works for me
          this.
          i had to cut both of them out when i changed my leafs a few weeks ago. I used a sawzeverything. 8 bucks a piece at the dealership
            I second Sam's solution..I have also dealt with this many times..Cut the bolt..and if need be start cutting the eye of the leaf spring apart..At least you will only have to do this once..After they are greased they come out easy everytime..(hardy har thats what she said)
              i can't tell if it's unthreaded all the way yet. thats really the only reason i don't want to cut em.
              i'll have to investigate more tomorrow and hopefully i can cut them and call it a day. just making sure noone had a trick first.
              thanks guys
                FIRE!
                  fire would be great if it wouldn't make a damn mess out of the rubber bushing and still not get me anywhere lol
                    actually now that i think about it the bolt is already backed out pretty far. if you just cut it and hammered it back in a touch it'd prob all be in the bushing and you'd be able to drop the leaf
                      this.
                        antiseize on everything when you put the lift in.
                        no, fuck antiseize.
                        never seize. that gold shit.
                          getting new bolts all around today, this evenings task is to cut all 4 and replace with freshy fresh ones
                            Bushings stink when you melt them.
                              good luck gettin them out i would just cut them and get new ones
