Was sitting at a drivethru and at idle, engine starting vibrating and making a noise, wasnt sure what it was. Check gauges light came on and alternator wasnt charging. Drove 2 minutes home and at low speeds I would lose power steering also.
After closer inspection, it appears as my harmonic balancer failed, and separated. Anyone know what would cause this ? Or is it just a random parts failure that happens after 90,000 miles?
Video to see how loose it is.
View My Video
<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v5.tinypic.com/player.swf?file=2m6omqu&s=5"><br><font size="1"><a href="http://tinypic.com/player.php?v=2m6omqu&s=5">Original Video</a> - More videos at <a href="http://tinypic.com">TinyPic</a></font>
Is this something I should just pull and replace?
View My Video
Not the first one i've seen do that buddy, pull the 3 bolts get yoself a cheap puller for like 20 bucks and pull it using th eother 3 holes (the little ones) and put a new one on, make sure it seated tight though where its supposed to be. you could impact it on ot tourque it with a tourque wrench* *recommended way
.............. that thing is fuckeddddd like said b4 dont put a junkyard one on it could be almost at this point go with a new one
