proportioning valve leakage
  • proportioning valve leakage
    so my proportioning valve is leaking. i'm not familiar at all with braking systems. it's leaking from the large nut thing on the end. you can kind of see the fluid coming out in the picture. i tried tightening it but it wouldn't budge. i didn't want to try too much because i wasn't sure if i was even doing the right thing. is there anyway to stop it from leaking or do i need to replace the whole thing?
    1987 YJ
    I'm still learning...
    how much is it leaking?
    I would make sure that its where its leaking from. if it is, maybe take it apart and clean it with break cleaner and see whats up.... maybe the o-ring is shot
    careful, there is a spring in there that will shoot the cap out!
    check out this site: http://www.lunghd.com/Tech_Articles/..._Valve_Mod.htm
    edit: do all prop. valves look like this on jeeps? mine has a cap at the end with a bleeder under it, yours looks like its missing the bleeder? Am i wrong?
      Dana is right there are a couple o-rings in there just take of the bolt watch out it is spring loaded replace the o-rings.
      As long as the piston is scored or cracked you should be good.
      The hole in the bolt is just for a vent.
        thanks for the info. i think you're right about the bleeder being broken off. i'm going to do some more research. its leaking pretty bad. i have to fill up the master cylinder every couple of weeks
        1987 YJ
          took another look at it today. its definitely broken off. looks like i'm going to have to get a new one. i don't think anyone sells just the bleeder
          1987 YJ
            :swish: lol, go to a pick and pull maybe.
              does anyone happen to know if a cherokee valve will work on my yj?
              1987 YJ
                pretty sure mine is the same as yours. i have a 93 xj
