3rd Gear Bogging
  • 3rd Gear Bogging
    So the other day, i got home from school and the jeep was idling unusually high. So i adjusted how high it idles and now when ever im on the gas pedal, i hit 3rd gear, and loose all my power, when i start to let up off the pedal, the rpm's spike back up. Is this from a dirty gas filter?
    On the other note, is there a special size bolt that moog track bar bushings use? I put the bushings in, and went to put the original bolt back in and it doesn't fit. Since i needed the jeep on the road asap, i threw in a bolt a bit smaller than the original one, but it's small enough to cause movement on the track bar (the bolt is on the unibody side of the track bar) which is giving me d.w once again
    Why would you adjust your idle? I woulda just tried to figure out what was causing the high idle. Put that back to where it was and see if things change
      it was idling at like 12-13 hundred rpm
        still. i woulda looked around to figure what was causing it. Like i said, reset it to where it was and see what happens. Whenever my XJ randomly idled real high I just gave it a quick stomp on the gas and it went away
          when i was looking for a cause, i stumbled upon a broken map sensor vac line, i put a piece of hose to act like a sleeve, no other vac lines are broken, but ill adjust it tonite or tomorrow
