So I raised my rear shock mounts to my axle tubes. I was like o hai raised them about 2-3 inchs and I have like 3.5 inchs o lift so a stock shock should work, well I dont think so. I have less droop now because one shock will compress all the way and the other one cant extend due to this. So can I get a shock with a longer shaft and short body? would that work? What about "inboarding" the rear shocks? Can some one explain the inboarding? Would I use a longer travel shock and make a mount for putting it inside the jeep?
A Shocking Question
Originally posted by XJtheXtremeJeep View Posthow does it work in theory? the stock shocks are a shorter travel than the 3.5 inch shocks. thats where you lose the wheel travel in the end, inboarding them is a good idea then you can run longer travel shocks easier.
Caleb- BBC's will fix itLast edited by Ruepart Hoaxley; 03-18-2010, 01:54 AM.2000 XJ: "The Black Jeep"MK2 Jetta > M3Chairman of the Chechnyan Space Program
