wj rear lca's in xj
  • wj rear lca's in xj
    Has anyone ever dont this...i read there 2 inches longer and just need to cut the bushings to fit. I was thinking if i did this then i could add some spacers to get some more lift.
    Also does anyone know if the sway bar links from anyother jeep/car/truck..would fit onto the cherokee and be like 2 inches longer.
    Thanks
    i know alot of people use the fronts i've never hears about anyone using the rears. i have a set of both front and rears if you wanna buy them from me and try it
    wj 4" lift 32s jk moabs arb, waiting to go in aussied 44 with 4.56s rock krawler long arms jks rock rails 34" narrow swamper tsl's
      how much?...im just thinking of ways to get some more lift. it seems every time i think, i come up with ideas that start of cheap but then blow up untill its the same as a new lift.
      My new idea is a tcase drop new or used, wj lca's, mj shackles, 1" spacer, but unless i find some sway bar link idea it wont be so cheap.
        how much lift are you planning on running in total?
          im at 3" and would like 4 or a little more...
            what size tire are you running?
              do a spacer in front, adjust pinion angle. do a shackle in rear, fab a tcase drop, call it a day.
                33's will fit with some trimming at 3 inches, if that was your planned tire size
                  Originally posted by SwampThing View Post
                  35's will fit with some trimming at 3 inches, if that was your planned tire size
                  fixed
                    If you are that concerned, throw a 3/4 inch spacer up front and a 3/4 or 1 inch shackle in the rear and buy some adjustable lowers.
                      Truth.
                        37's will fit with some trimming at 1.5 inches, if that was your planned tire size and your name is sam
                        fixed just to let you know that trimming and bumpstopping goes a long way
                          Originally posted by 93XJRay View Post
                          fixed
                          never happened
                            i see what you did there
                              i trimmed the front but dont want to cut anymore....with my flares on, even though they dont hide much, my mom has not relized i cut more of my jeep away. Im waiting to cut the rears. But my xj sits really low...next to some ladies xj with a 3.5 skyjacker lift mines like 1-1.5 inches shorter.
                              Im on a budget so i wanted any cheap way, i was planing a 1in spacer and shackle,tcase drop. an just didn know if i would need control arms or sway bar links at 4 inches.
                              i want to runn 32-33 inch tires if i get money, but i have 31's right now
                              creepywj..could you tell me are the wj rear lca's longer then the fronts??? just want to make sure if they really are
