Making a bastard pack.
  • Making a bastard pack.
    So Ill be making a bastard pack on Sunday hopefully. Do I need to get a longer centering pin for stock leaves? Are they just grade 8 bolts? Do I need new leaf clamps? Can I get those at Autozone or something? Anything else I ned to know?
    I'm pretty sure I remember a while back Drew was trying to make centering pins from grade 8 bolts. He said he had to grind the bolt head round in order for it to fit.
      I have seen hose clamps used as leaf spring clamps and grade 8 bolts are fine. 5/16 should work.
        autozone has them but theyre 20 bucks for two.. cheap and easy to fab some up.
          ive seen this too but how good does it work? i would figure a hose clamp wouldnt hold them together all that well
            i use grade 8 allen head bolts when I can
            or just grind some bolt heads down
            5/16" is stock
            re is 3/8"
            not sure about other aftermarket packs
              I used regular hex head bolts and ground them down on the bench grinder.
                I tried to find longer center pins, and the only way levines could get the size I needed was to order a whole box
                I would just grind down the heads of some grade 8 bolts.
                  I used the allen cap screws they worked good and didn't have to grind em down
                    x2 and they are grade 8
                      we used allens on 4bangerYJ's springs because the original ones broke when we took his axle out..
                        if you're looking for center pins you might also want to check at Perraults in Waterbury... they might be able to hook you up
                        -Tim
                          Superior Spring.
                          RM
                            theyve got a shit ton of them, last time i went he gave me one for free cuz the thread were kinda smooshed, took it home and chased em, worked great
                              This. Is exactly what I did because one of them snapped and it was too late for any of the parts stores to be open. Worked perfect still no problems
