just an fyi
  • just an fyi
    a 4.0 from a 97 is not a direct swap to a 98 cherokee we found that out the hard way luckly we still had the oil pressure sending unit.. dizzy.. throttle body and one vac hose..but i now no longer have a nasty lifter tick
    i directly swapped a 98 4.0 in a 91
    the only difference was the was no slot for the temp sensor so i made one
      i think he mean's the wiring harness plug's, when i swapped a 4.0 from an older cherokee into my 95 grand cherokee i had to switch a few of the sensor's over and still have to tap a spot for temp sensor.
        when i think engines i think engines
        not engines with everything bolted on them with wiring harnesses galore.
        97 is a bastard year for wiring.
          joe who helped you do that?
            what would be the ideal engine swap for a 89 cherokee? something found easily, inexpensive and not an insane amount of modification?
            I need to get rid of this renix
              another renix
                another renix
                What needs to be done to swap in a newer engine?
                  a 91-99 4.0 in your jeep would require the wiring harness, all sensors, computer, and more headaches than its worth imo.
                  nothin wrong with a renix
                    john and a few other buddies
