ok so the inside edge of my baja claw is worn down so the tire is obv angled / but i knew that, so today im going to work and i get these horrible vibrations when on the throttle but when in off the throttle is not there regardless of speed or rpm... u joint? motor mount? any ideas its drivin me nuts how bad is vibrating
gotta problem
How about you get a wheel alignment.Last edited by Buffalo Phil; 01-06-2010, 11:43 PM.sigpic
oh damn, better part out your jeep.
get an alignmentP8R
sounds like a u-joint to meup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
Then I would do that. If you tires are on an angle your vehicle is going to ride like shit. How do you know it isn't a ball joint a a bad hub?Originally posted by WTNFDXJ View Posti gotta install the won ton steering first then ill get an alignmentsigpic
sounds like a driveline issueOriginally posted by WTNFDXJ View Posti get these horrible vibrations when on the throttle but when in off the throttle is not there regardless of speed or rpm...
gotta sye?
whats yo pinion angle at?
grab yo shafts and wiggle em all about and make sure nothing is worn
