hokay so. i've flat towed one thing in my life and that was for a short while behind my jeep with a tow bar. how do i go about attaching some sort of tow bar on my jeep with the bumper being so much higher than stock? it will be getting towed by a RV, so i'm guessing the hitch will be kinda low. i have a tow bar, but is there some special one i need? can i take a drop hitch and flip it upside down or something? and this needs to be 100% safe, its gotta stay back there for a LOOOOONNGGGG time.
flat towing a lifted cherokee
you can take a drop hitch and flip it upside down1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
there is a few different styles of tow bars, and honestly they all are garbage. I know Mike R who was flat towing flipped his xj because the bar broke on the high way. You really should just looking into a dolly and pulling the rear d/s1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
Attach car tow bar to the vehicle that will do the towing, by holding tow bar parallel to your rear bumper. Hook metal clips around top of bumper to hold tow bar in place. Hook lower clips on tow bar to the bottom of the bumper and pull slack out by pulling the excess chain through the retaining holes and lock in place by sliding chain into socket on bumper hitch. Tighten tow bar by turning wing nuts on chain to tighten the remaining slack.
Step
2
Attach A-frame tow bar to vehicle to be towed by holding the base of the A-frame parallel to the front bumper of vehicle to be towed. Attach metal clips on tow bar to the top of front bumper to hold in place. Attach lower clips to the bottom of the bumper and pull slack out of chains by running through retaining holes and locking in place, sliding chain into slots on bumper and turning to lock. Tighten A-frame tow bar by turning wing nut to draw slack out of chains.
Step
3
Move A-frame into place by having someone slowly drive vehicle to be towed into position while someone holds A-frame up and directs driver into position. Lower A-frame ball socket over the hitch ball on the car bumper hitch of the towing vehicle. When ball socket is completely seated over hitch ball, tighten screw over top of the ball socket to secure. Connect chains from A-frame to the frame of the towing vehicle (this is a safety chain).
easiest explanation i could find1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
Ive never seen a tow bar that attaches just to the bumper. Imagine a setup like that on a stock XJ bumper? I see setups all the time on WJs and other jeeps that are attached to the unibody and come out under the stock air dam or where the tow hooks are. So its firmly attached and then the A frame is attached to that.Lady bugs don't like it when you paint stripes on them
