CB ban radio
  • CB ban radio
    Anyone use CB? i am thinking of putting it in my jeep more or less just to screw around.
    how hard is it to install? how exspensive? can someone point me in the right direction and give me some advice?
    thanks
    tim
    -54 Dodge Power wagon M-37
    -57 GMC Pickup
    -Tim (OIIIIIO)
    I had one in my last XJ. Not too expensive, for about 100 dollars you can have yourself a nice little setup. You need to find a place to mount the antenna. The higher you mount it, the better reception and range you will have, but the more you will wack it on trees and such on the trails. I would not recommend mounting it on the side of your jeep. I bought a mount and drilled a hole in the side of my jeep, but was always hitting it on trees and if I would have hit it hard enough, id fuck up my jeeps body panel. If you have a 97+ Up XJ you can mount it to your rear hatch since its metal. The older XJ's have fiberglass hatches. You run a ground wire for the antenna, and then run a wire from the antenna to the back of the CB radio. To make the CB work right, you need to tune the antenna with a SWR meter. They cost around 20 dollars at radio shack, or you can find someone who has one and borrow. You will only need to tune the antenna once. Run power to the CB radio and your in business. I tapped mine off my fuse block to the accessory fuse so when my jeep was off, the radio went off too.
    Its cool to have. I would bullshit with truckers when i was on the highway, they would tell me where cops were, if there were traffic or accidents, it was cool. Also, good to have on trails. Lots of people run them in their jeep and it makes communicating between vehicles mucho easy.
    Radio shack should have everything you need, radio, antenna, wire, swr meter.
      radios are all the same, dont cheap out on an antenna or the mount.
        i have some cb stuff i want to get rid of antenna mount and cable you would just have to find a radio. all this stuff is new
        98 XJ 4.5 32inch cooper STT DC-1 black KC daylighters 4.10s
        Its not just a jeep.
          might be interested, i am off on vaca till sunday but i will be inquiring and doing somemore research but thanks for the help so far guys, keep it coming!
          -57 GMC Pickup
          -Tim (OIIIIIO)
            no prob
              no prob
              is it hard to install? and what kind of a radio should i look for?
              -57 GMC Pickup
              -Tim (OIIIIIO)
                the hardest part is figuring out where you want to put the radio and mount the antenna other than its just running the cable and securing everything but no its a pretty easy task
                  what do u suggest for a radio i dont want anything crazy i just wanna talk around town with some friends. should i grab something off the bargain news for like 20$?
                  -57 GMC Pickup
                  -Tim (OIIIIIO)
                    yeah as long as it works a radio is a radio. i picked up a $50 special at wal mart. i like it, its small and works great. takes up almost no space
                      i have a nice modded cobra 29 in my closet not being used.. might wanna sell it..
                        i am leaving for vaca in like 5 min i will be back sunday and i will message u, in the mean time if u wanted to take some pics that would be sick!
                        -57 GMC Pickup
                        -Tim (OIIIIIO)
                          Doesn't most of SiS use the roll down the window and yell method?
                          Is it egg nog season yet?
                            it is my preferred method of communication
                              i more or less want it because i race dowhillmountain bikes, witch requires me to drive 3 plus hours just to get to a mountain , so i can find out where the cops are so i can shorten my drive time , and keep my insurance rates down!
                              -57 GMC Pickup
                              -Tim (OIIIIIO)
