DOM Tube/Straight Bar
  • DOM Tube/Straight Bar
    can someone explain to me wtf I am doing wrong?
    I keep pricing crap out on this website
    http://www.metalsdepot.com/index.phtml?aident=
    and aluminum keeps coming up cheaper than steel?
    Isnt aluminum a lot more expensive?
    Am I putting in the wrong sizes?
    For cage/chassie work what is the normal tube size you use?
    Then bar for control arms?
    Don't you want the home depot? They have a vast assortment of 90s and 45s and all different sizes of threaded pipe!!! That shit is way bigger than the tube you're looking at!!
      make your main cage out of 1.75" diameter , typical is .120 wall
      1.5" for less "critical" parts if you want
      1.75 is becoming the common ruled size for sanctioned events
      control arms 1.75"x.25" tube is a pretty average standard, though guys fuck up stuff thats more intense than that also..what is this for?
      i see Total:
      $101.40 for a stick (20 feet) of the DOM i mentioned above for cage elements.
        ah shit, i didnt mean to link that page
          i see Total:
          What about bar? Like 1x1 or what? Like clayton arms?
          Im just experimenting for a future project. Turns out one of the guys that just moved right by me(works in my office) use to fabricate sique nasty shit. He did Trophy Truck chassies/race car chassies/ pretty much everything.
          He said he would tech me everything.
            you mean like square tube stock? i dunno, i see no reason to play with a proven round tube design..bar is typically solid lengths, and tube is the common standard
              I appreciate the input and will take this into consideration for all future investigation
                Thats the most expensive place on the planet to buy metal from.
                  I was just trying to get a aluminum to steel compare.
                    Depending on the aluminum it will be cheaper. 6061 (general purpose) aluminum is pretty cheap compared to steel.
                    Bent Fab Evo4 Rockwell Buggy
                    2011 Silverado 6.2L LT
                    2009 Pontiac G8 GT
                    2004 Z1000
                    1999 TJ
                      This. Aluminum is easier to machine and mold to get it the desired form.
