Low cog suspension setup, tips/tricks
Tags: None
Some perspective from a non-jeep. This is my deterimined ride height for now. I maybe able to get it a couple inches lower then it currently sits. But I also cut the fenders and removed the rockers to tuck up the sliders.
Before the Fenders:
After the fenders:
To keep my truck low, I had to get a different set of motor mounts and oil filter relocation kit.
These motor mounts come straight out from the block and mount over the frame rail. This allows enough room on the side of my engine for my 3links upper link.
I then made a new trans crossmember so that I can build a flat belly skid.
2011 Silverado 6.2L LT
2009 Pontiac G8 GT
2004 Z1000
1999 TJ
Awesome thread... I hope to get 36" tires on my cherokee eventually... After some regearing and a rear axle swap.1991 Jeep Cherokee- 4.5" Rough Country Lift - 33x12.5x15 BFG M/T KM2's - Crager Soft 8's
yeaaaa alot of the xj guys on here, which is a lot, run low COG setups, there are quite a few of us running between 3-4 inches of lift and 33's or 35'sOriginally posted by kev711 View Postthanks so much for posting this. i'm still trying to learn and this helped me realize that i don't need 10 feet of lift. sure makes me feel better about my lil 2 1/2in rancho
nice write up, I cant wait to have enough money to change my lift out for a smaller long arm setup.up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
I'm sure most everyone realized this, but I figured I would bump it for fun.
Almost all of the topics you discuss relate to low COG setups in general, but there are a couple places where you speak more about XJ specific setups. I just figured I would point it out in case you wanted to edit something in the post, or in the title itself.
And while I'm in here, I'll give you a question/discussion. In a few places you mention how a flatter control arm angle will give superior droop compared to a taller suspension. Just playing the devils advocate here, but you seem to talk about suspension droop much more than compression. I see where a flatter control arm angle would give superior droop, but I also see where a more angled control arm (taller lift height) would allow much more uptravel. I'm just trying to add information to the topic, so feel free to school me on this subject.
Very good write up
