peepz running prothanez
  • peepz running prothanez
    how much free space do you have? and how much do they compress?
    kthx. <3
    my upper bumpstop sits about an inch above the top of the prothane and it actually compresses quite a bit.
      umm
      what keeps the prothane from eating the stock bumpstop and the prothane gettin all stuck in that biznitch?
      anyway
      i ran zero inches of free travel with them bent rustys 3" coils.
      and when i ran tomken 3" coils i had about 2" of free travel
      and when i had no name 2" coils i had like .5" of free travel
      they will compress to about half their size
        my prothanes are basically destroyed after 2 runs from the stock bumpstop
          i figured they'd compress to about half. im gonna cut the stock rubber jam off and put a piece of plate their so the prothane has something solid and flat to compress against.
          thank dudes.
            told you
              my prothanes are fucked and i need to fix them asap as well. adam if you weld a plate on the bumpstop towers make sure the coils will fit over them or you won't be able to fit em anymore. obvious yes but i could see it happening
                I just put mine in, I didnt take any pics tho. but what i did was cut out a round piece of metal and welded it to the upper bumpstop tower. What Im hoping this does is prevent the tower to dig into the bump stop and have it hit the prothane more evenly. I have about 2 inches or so of free clearance between.
                  yea i saw of pic of someone on NAXJA who did it like this and saved the pic. andrew over at havspeed owes me lots of favors for my tech support and video work so he's welding all my jamz.
                    i bolted a plate to my upper bump tower
                      x2. the hole in the upper tower fits a 1/2 bolt perfectly.
                        pic?
                          it looks like a round plate bolted to the bumpstop tower beleive it or not
