mj to XJ lift question
  • mj to XJ lift question
    i was thinkin today is anything from a XJ swapable to a MJ 4wd? if so what?
    For lift kit wise?
    Everything in the front will be good to swap, control arms, coils, brake lines, whatever in the front of your MJ will go in an XJ.
    For the rear, im not to sure how comanche lift kits come, but i know that MJ's are spring under and XJ's are spring over, so you may net more lift in the rear if you use the same leafs. Other than that, shocks, and brake lines can be swapped.
      i think the rear leafs are longer on a mj, waiting for corey to chime in
        hmm tempting to do a MJ
          you already have like 4.5 inches up front, spring over the back and see how it sits.
            Mj springs are about 5 inches or so longer than cherokee springs and have more arch stock, much more. You get about 5.5" or better lift with the spring over. It's actually too much.
