Flushed heater core, gauge stopped working
  • Flushed heater core, gauge stopped working
    Well in my quest for heat I flushed the heater core, lots of brown shit came out and everything seems to run fine now.
    I get heat a lot quicker than I did before and it blows hotter. The only problem is my temperature gauge stopped working right after this.
    Any ideas on what the fawk happened? Both hoses are hot so coolant is circulating. is the tstat fucked? sensor? gauge coincidentally stop working?
    87 Comanche 4.0 4wd
    the needle on the temp gauge goes all the way to 260 when starting it up, which is normal. When I pull the CTS off the electric fan kicks on.
    87 Comanche 4.0 4wd
      Where is the gauge when its running?
        the gauge is all the way to the left. not looking at it but im guesing 160? just like if it was cold and had been off for a while.
        87 Comanche 4.0 4wd
          sounds like the sending unit is either unhooked or its bad
            This was the problem. thanks for the help
            87 Comanche 4.0 4wd
