what did i break now?
  • what did i break now?
    ok so i put a new fuel pump in the 93 xj because the old one was acting up. it wouldnt start because the pump wouldnt turn on until cranking it over and over. so i replaced it, now the NEW pump wont turn on at all and the jeep wont start at all... is there a safety thing where if i screwed up some wires it wont turn on at all? is there something else i couldve screwed up that would cause the new pump not to turn on at all? i need some help here idk what the fuck i did...
    Did you plug it in? All the hoses in?
      yep, plugged in, all hoses in, the sock is on it.. oh and the fuse is good too..
        bad new pump?
          what brand fuel pump?
          anything you get from autozone or advance is garbage
          and half the stuff you can get from napa or carquest or other like stores is garbage
          i have gone through about 6 advance pumps in a few days (airteks) before i put the soaking wet pump on the counter and demanded my money back.
          some wouldnt work at all and others worked for up to 30 miles then failed leaving me stranded
            oh
            and ill sell you a good bosch fuel pump with sending unit with a new lock ring and o ring for cheep if you like
              oh
              dude i got the good bosch one. i even got a new bosch sending unit and everything and put it in today. i figured out i had no spark. ign coil was bad, so replaced that...still wont start...
                do you have spark now?
                  sounds like a crank sensor issue to me. do you have spark and/or injection pulse? check both of them
                    Those stupid crank sensors.
                    You're a ___________
                      cps is brand new..
                        do you have fuel pressure? how much voltage at the batt? injection pulse?
                          your throttle stuck open?
