Might go Limited Slip
  • Might go Limited Slip
    Here's the deal. I found a 8.25 in a '99 XJ with a factory limited slip so then I'm assuming it has 3.73 gears. I can pull the carrier for super cheap. I can take the whole axle for a reasonable price. I don't have $$ to regear my D30 so installing the whole axle isn't viable in the short term and I'd like to go more towards 4.56 next summer anyways.
    Questions:
    What's involved with pulling the carrier and installing it in my XJ with 3.55 gears? Any problems?
    Is there a carrier break/size difference in there somewhere?
    What additional parts would I need? Is this something a novice should be doing?
    What don't I know that I need to know about this?
    I realize what a new lunch box locker costs and I'm sure many of you would suggest going that route and getting an Aussie....but entertain my idea instead for now please.
    I'm not set on doing this but if I can do the work myself with my limited skills and keep the cost down I may go for it.
    It would basically be a whole regear if you tok the carrier and stuff out and that would not be worht the money. Your better off getting an aussie and then saving up for a regear in the summer or w/e.
      not worth it, factory LS is junk anyways
        Just put in a lunchbox locker and call it a day.
        You're a ___________
          pulling the carriers on them are a pain in the ass they need a special tool to set them. factory lsd's are garbage, get a lunch box locker instead
            not likely
            3.07s if it was a standard or 3.55's if it was an auto. there were no other options that year unless it was regeared later down the road
              OK - so it doesn't sound like its worth the effort.
              I figured 3.73 since it came with the tow package.
                not likely
                nah son 3.73s came with the tow package.
