What would cause this to come on?
airbag light
Its really common in older cars, its normally the clock spring or in Mopar cars there is a "pigtail" wire connector somewhere in the dash that connects your insturments. It could just be corrision or dirty connector. I personally wouldnt worry about. When the light is on it means your airbag is disabled.
Airbags actually worry me, I know they are good in some cases, but I was on I70 in maryland once doing about 85 at night trying to get to my base and TWO deer ran out in front of me and I hit them both destroying the front of my car. I had this problem in that car so I disabled the air bag. I believe if I hadnt and the air bag went off I would of died. I was right at the crest of a mountain with a big turn going down. If the airbag went off I wouldnt have been able to see and at that speed I would of went off the side of the mountain or into uncomming traffic or slammed into the huge bridge barriers right at the top.You better decide if you are hanging on the cross, or banging in the nails
they are usually clock springs but it might also be a sensor.
throw a scanner on it and find out. I don't know if mine will read air bag codes.
Most garages will help you out.
To disable the air bags on the XJs there is a little round cover on the top of the steering wheel pop the cover off and there is a 10mm head bolt in there back it all the way out until it stops.
Good to do before wheeling, I know Sam enjoyed the smoke show during the comp.RCrocs #123 Brown CJ-5
kind of off topic, but are there sensors for airbag mounted in front of the jeep somewhere or is it just a force meter type switch that sets them off ? I've hit a boulder hard enough to crack my 3/6" boxed front bumper and bend it back like 4" and airbags didnt do anything... also had a commanche rear end me at 45mph bending my 1/4" rear bumper mounts and nothing
