Jeep lost its power
  • Jeep lost its power
    here is the deal. I got too used to my 4 cyl comanche. Now that i threw 33's on my stock geared 4.0 auto 99, it has WAY more power than my 5.38 geared 96 on 35's
    something is not right here.
    its a 96 4.0 aw4
    the power only kicks in around 4250 rpms and even then it isn't too impressive. other than that it just kinda lugs along. I can still get it up to highway speeds no problem and cruise along just fine.
    new parts:
    plugs
    wires
    cap
    rotor
    cps
    o2
    air filter
    fuel filter
    alternator
    battree
    tps,map, and iac are all good
    Hooked it up to the scanner and everything looks fine, no codes.
    Not sure where to go from here.
    any ideas?
      comrpession test... hows the airfilter? it this motor stock?
        maybe monday
        new
        yes
          If everything you say is good, I would def check the motor out and do a compression test. notice any excess oil or coolant usage? maybe cracked the head or bad head gasket.
            OKAY
            narrowed down my issue here
            fuel pressure is at 38 running
            stock calls for 49 + or - 5 psi
            so its a fuel delivery issue
            is it safe to say it's my fuel pump or are there a couple more things i could be checking
            can't be the regulator as that would give me too much pressure correct?
              isnt this like fuel pump #142? whats the deal with that shiat if thats the issue
                confusing me with someone else? or goin all on me?
                this is the factory pump
                  didnt you change your fuel pump like 4 times? wtf i could have sworn...
                  green jeep maybe...
                    green jeep maybe...
                    yea green jeep
                    late 2007
                    fuckin airtex pumps
                      it was the fuel pump, she can roast tire again
                      funny thing is, i would have never thought something was wrong if i didnt throw 33's on the stocker
                        you'd make a good crew chief on a jet sam
                          IAT will make the ECU pull timing. Check the ohms and see if its in spec.
