motor compatibility
  • motor compatibility
    Im possibly getting a 95 cherokee MINT but it has no title.. it has the 4.0 HO in it my question is will that motor go into my 98 XJ with no problems?? and is the HO really that much of a differance i want it becuase it has less miles than mine and its all rebuilt
    It will be fine. You need to use the 98 harness and maybe some sensors but than that it should be the same.
      Isnt every 4.0L built after 91 a HO?
      Bent Fab Evo4 Rockwell Buggy
      2011 Silverado 6.2L LT
      2009 Pontiac G8 GT
      2004 Z1000
      1999 TJ
        i swapped a 98 in a 91 without issue, the only difference is the 98 didnt have a spot for the coolant temp sensor (guage only) so i drilled and tapped my thermostat housing.
          i'd say about the only difference would be some sensors and your injectors ( easy to change)
            ummm yeh
