comming from the passenger side rear of the vehicle. i'm thinking its the bearing in the 44, the seal was leaking gear oil about a week ago but hasn't been since. just wanna make sure i'm on the right path here. bearing??
clicking and grinding noise
this...also if a bearing is bad it will be loud as hell. It will sound like you are running a bogger or something hahaOriginally posted by Ktmracer419 View Postif a wheel bearing is so bad its clickin and grinding, jack up the axle and you should be able to pull the tire up and around ervery which way.
GREATOriginally posted by CumminsJeep View Postthis...also if a bearing is bad it will be loud as hell. It will sound like you are running a bogger or something haha
because whenever i blew out a wheel bearing i couldnt hear it growling over the loudness of my tires lol.
Its when the bearing began falling apart and either burning up my gear oil or locking up causing my jeep to jerk on the highway when i noticed it.
one time i noticed it around town and could hear pieces of the bearing fall out and rattle in my drum
hahahahahaha I guess thats what happens when you run something loud like IROKSOriginally posted by Ktmracer419 View PostGREAT
lol it's deff the bearing, it's loud as fuck and theres gear oil dripping out from behind the drum whenever its parked.
i'm gonna pull the shaft (
) tommorrow and replace everything
