gauge cluster swap.
  • gauge cluster swap.
    Im swaping out my gauges on my jeep and i was wondering if its bad for the speedo gears or w/e to roll them manually so I can get up to the same miles i have? Anything else I should know about the swap?
    Im assuming you are swapping from the lame dummy gauge setup to a cluster that shows the oil pressure, engine temp, battery, fuel, rpm and mph. I did the same thing but the engine temp gauge and oil pressure gauge appear to be screwy. Not sure if its just my jeep but you may run into that issue.
    As for the odometer i dont know what to do with that.
      I read a write up on NAXJA and you have to change the oil pressure sensor and the temp sensor.
      http://naxja.org/forum/showthread.php?t=101116
        i just read that. interesting. ill have to look for the back one and swap that with my grey jeeps one along with the oil sending unit. i figured it was the oil pressure sender in that case.
          Yeah, I have to go buy the sensors. I just swapped the gauges and said srew it ill right down the original milage.
            You should be able to roll the odometer, as long as you only plan on advancing, I'm not sure that if your going back it'll be fine
              who's to say you couldn't "advance it" passed 999999 and bring it back down to low miles. the inner carsalesman is coming out in me
                I have the speedo from my old 87 xj and you can roll the odometer with a drill, dunno if that will work on yours.
