hmmm. how do i put this... my slip yoke eliminator kit is... slipping. every once in a while ill either get a light clink clink clink noise or u joint type vibration depending on the speed im traveling, so i got under the jeep and noticed the yoke on the sye was pulled forward, out of the back of the transfer case, i can slide it back in but the yoke and the output shaft can move up down side to side, but only the yoke can pull in and out along the splines... porc has a lifetime warranty against it breaking, but im wondering if this is a semi common problem that can be fixed without getting a new kit
sye problem
well it was fine for the longest time, until about a week or so ago i noticed the play in it
i found out whats making the yoke slide though, the nut at the end of the output shaft unthreaded and is just hangin out in there next to the u joint2005 Jeep Wrangler Rubicon Unlimited
1945 Willys-Overland CJ2A
