Just a ? im adding another 1.5 inch lift to my jeep wich has a 3 inch already. with a shackle and spacer im also going to do a t case drop. will i have to get longer drive shafts some one told me i do also will my shocks be ok and anything else i should do ?
shackle spacer
did you hammer up your inner fender seam?
also what are you doing for bumpstopping?Last edited by wannabejeep; 07-31-2009, 01:49 AM.1993 XJ sport 3.5" rustys 33" MTZ's armored.
you should have no problem fitting those
let your balls drop and trim a little
and either way you will have to bumpstop, lift doesn't stop your suspension from compressing, bumpstops do.
especially if you don;t bumpstop with the spacers and shackles, those springs won't last very long, they are only meant to compress so much, and the shackle and spacer allows them to compress more than designed
Originally posted by Ktmracer419 View Postlet your balls drop and trim a little2 tj's
my fenders are cut i was going to buy the shackle and spacer today from raze. but he never brought it which. i dont think he even has it. i think it was bs to make me waste my time going down there. anyways im getting bumpstops which should help alot speaking is i have none i went to evb today and they put it on the fork lift and said i need 6 inch bump stops i can only find up to 4 inch ones im not shure if evb is right. what size bump stops are you all running on a 3 inch lift with 33s
Originally posted by jeepinjosh View Postmy fenders are cut i was going to buy the shackle and spacer today from raze. but he never brought it which. i dont think he even has it. i think it was bs to make me waste my time going down there. anyways im getting bumpstops which should help alot speaking is i have none i went to evb today and they put it on the fork lift and said i need 6 inch bump stops i can only find up to 4 inch ones im not shure if evb is right. what size bump stops are you all running on a 3 inch lift with 33s
a 33" tire you need to trim a decent amountno matter what. unless you want to jack it to the moon and run stiff springs
Originally posted by Arundlemcbrundle View Postthis kid obviously doesn't do any serious wheeling so who the hell cares about his cog. if he doesn't wanna hack his jeep up then there's other options for his wheeling style
this kid also obviously has limited funding so going even higher will only increase the chance that he is going to need a SYE and driveshaft, which he also has zero chance of installing himself (once again, more money)
get the proper bumpstopping, trim them to look nice, and be done with it like we have told you from day 1
front bumpstopping is easy, John Maru(ninetysix-ex-jay) bumpstopped the front of his jeep before this weekend on 33" tires and he needed 3 hockey pucks on each side, so do that and go from there
for rear bumpstopping i bought spring plates from DPG Offroad with 2 bumpstop plates - http://www.dpgoff-road.com/site/dpg_...top_plates.htm
and quadratec 4.1" bumpstops - http://www.quadratec.com/products/52422_01.htmLast edited by Even; 08-03-2009, 05:29 PM.
Originally posted by jeepinjosh View Postmy fenders are cut i was going to buy the shackle and spacer today from raze. but he never brought it which. i dont think he even has it. i think it was bs to make me waste my time going down there. anyways im getting bumpstops which should help alot speaking is i have none i went to evb today and they put it on the fork lift and said i need 6 inch bump stops i can only find up to 4 inch ones im not shure if evb is right. what size bump stops are you all running on a 3 inch lift with 33s1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
