I think the leafs in the rear would work, leafs give you a nice constant roll center and stuffing the mounting points up higher in the body will actually raise your RC (Leaf RC is the line between the frame mounts directly over the axle)
Leafs suck for axle stability, basically a spring holds your axle in place so the whole axle moves around where ever it gets pushed. Like hard corners the axle will shift to the side. Pan Hard would help.
When you hit something hard the axle will push backwards as the spring straightens out then springs forward.
Never mind axle wrap.
Leafs wouldn't be as bad in the rear as the front you need the stiff front for drops and steering, and approach angle is more important then deproach angle.
Having a Leaf sprung vehicle I watch those axle move where ever they want.
My next jeep is going to have all links what kind I have not figured that out yet.
They all have their trade offs.
RCrocs you should be able to build it for class 3 / WE-Rock Promodified.
I would check the rules so you can meet as many classes as possible.
RCrocs, WE-Rock, KOH, Rausch Creek Racing, Southwick Racing
Everyone that rain Air shocks said they faded by the end of the race.
Give me a couple years to save and I'll be building a go fast rock crawler too.
I'm just dreaming up Ideas right now.
