enine boom ?
    crank sensor tested good. FML
      is the rotor turning on the distributor?
        ok so i finally figured it out after hours of diagnosing stupid shit and it ended up just being a bad coil. I ended up testing every input and output to the PCM, testing every sensor, removing the old aftermarket alarm system, and much more just to find that it was only a bad coil that could have been swapped on the side of the highway in 5 minutes. Shit happens and im just glad I figured it out and its ready for some more Rausch.
          Your bad coil cost me a day of work fucker
            thats the most expensive coil i hope i will ever go through
              hahah that seems to happen so often. The fix is something so simple but you over-complicate the shit out of it before realizing what is really wrong.
                wow, well atleast it was something easy lol
                  last time i had to pay to trailer my jeep home from the trail it was my sending unit unplugged
                  i'm glad you got it fixed though, maybe get an o2 sensor hooked up finally
                    never
                        actually while i was checking all my fuses i found a blown fuse for the O2 sensor heater circuit so i think my O2's are functioning now
                          now it wont make fun sounds
                            ha what sounds does it make?
                              optimus prime makes whatever sounds it pleases
